DNGRranger
1998 4wd 3.0 5spd...After everything I've installed listed in the title, my clutch action feels great! Problem; while the engine is running the truck will not go into gear! If I start the truck in gear the clutch drags. I bench bleed the master before install, I've conventional bleed at the slave and also used a vacuum bleeder. Probably 2 qtrs have been ran thru the system. My buddy(ase certs thru ford) and I are stuck. What should I do!?! I must be doing something wrong. Help!
