needle thrust bearing 88 ranger 4wd manual hub ?
swvapaver7274
Southwest Va
I have a 88 ranger 4wd manual hubs, just finished ball joints and axle u joints. On driver side which i done first, after i took off the wheel, then the hub i only had a locknut which takes a special 4 pronged socket, a holey washer and another locknut. When I got to the passenger side I had a c-clip, washer with splined center to go over spline, needle bearing washer looking thing, and a plain washer. I went to dealership and they said just use the c-clip and dont worry about the 2 washers and needle bearing washer thingy, so i dont have any on ethier side. This doesnt sound right to me, what will this affect? and where could i find the parts? thanks for your help cause i dont know who else to ask.....
The purpose of that needle bearing is to provide tension against the
stub shaft seal against the backside of the spindle.
On the D35 through '95 or '96 Ford used a simple heavy splined washer
1996 or so they went to a three washer setup.
and outer "thin" splined washer and an inner thin washer
with a plastic anti-friction washer between them.
While the torrington bearing used on the D28 was a bit of
engineering overkill... without SOMETHING there there is
no tension against the inner seal and mud/water/dust/dirt
can get into the spindle from the backside.
