Total different crank sensors and setups
The 1994 and older used a Hall Effect sensor, 12 voltsDC on/off type sensor and signal
1995-2001 used VR type sensor, generates its own AC voltage
So 1994 and older computer can't "understand" VR sensor
And 1995 and up computer can't understand Hall effect sensor
And there is no method to interface the two different signals, i.e. a conversion to match signals
Its not an AC/DC thing, the sine wave part of the AC signal is used, and ONLY half of it, lol, so you can't just add a rectifier to it VR sensor
The hall effect sensor "reads" a cup on the crank that has cut outs
Seen in this video, on how to install and setup, 1994 and earlier, crank sensor
Hall effect sensor is also inside the timing belt cover
1995 and up VR sensor reads a "tone wheel" or Reluctor wheel/ring
It has "teeth" every few degrees and each time a tooth passes by a VR sensor it generates AC voltage, so the faster it spins the higher the AC Volts, these are used for speed sensors and ABS wheel sensors as well
In the case of a crank sensor the tone wheel would have one tooth every 10 deg and one missing tooth to denote #1 piston at TDC
so 36 teeth minus 1 tooth, and that times the engine
Crank pulley on these has the tone ring on the back of it, and the crank sensor slides down a tube to be close but not touching the tone wheel
Since you have the 2.5l out already you can see how that works
People have said they mounted the hall effect sensor on a 1995-2001 crank and engine front cover
You would need to search for that
