MichaelPaladin
- Feb 16, 2011
- Automatic
History: 1999 Ford Ranger XLT w/ 3.0L.
Water Pump went bad and that was replaced, along with thermostat. and radiator cap. Had filled new coolant and air purged. Few days later coolant system over pressurizing and blowing some coolant out the overflow tank.
Took the truck to a mechanic, he does a power flush on the engine block and installs a new radiator,thermostat and cap. While on the his test drive the new radiator bursts along the seam. That gets replaced, and a few days later it splits open along the seam between the two connectors from the transmission cooler.
So now I'm on the 3rd Radiator, thermostat and radiator cap. There is no indication of coolant in the oil, nor is there any white smoke coming from the exhaust. Took the truck out yesterday for a small run, total actual running time was 20-25 minutes. But over two hours later, there was still a lot of pressure in the cooling system, enough pressure that it was pushing coolant out when I loosened the cap.
I'm looking for ideas as to what I need to check and fix to solve this problem.
Pic is of the new radiator, but in the area where the last two come apart at.
