- Mar 11, 2008
- Age
- 36
- Winnipeg, MB, CA
- Manual
You could see if a local quickie lube would let you use an empty bay for an hour.
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
besides the directions on the can, if i bypass those what is an acceptable temperature? what are the results if it's colder than the paint can work with?
The paint gets all weird and won't lay right.
Really, I would put the bedliner back in and forget about it until spring and fix it right. It has lasted this long and that is as bad as it is... a couple more months won't hurt much.
i'm not sure i really can.
the holes on the bed rails were from the topper.
the bed liner sat in there, and had like plastic pieces on the back side of the liner and the screws went into those. idk if i could get those plastic pieces back in there like that.
think it'll be okay if i just lay it in there and have sandbags in there basically all winter?
it's not like it would blow away with sand bags in there... but would it blow away with just being in there and tailgate up?
I got some of those stakepocket loops, unscrewed the loop and removed the square top plate but left the stud sticking out. I stuck some grease on the top of the stud. I let the liner fall where it wanted to sit, pulled it back up and drilled where the grease was. After that I pushed the studs thru the holes and installed the square top plate with the loop on top. Looks pretty sharp IMO and is pretty functional too.
And yes, the bedliner will fly out if unsecured (sandbags would hold it in) and they will fly surprisingly far too. With mine the back ends would move around ALOT and wear on the paint before I did the stakepocket loop trick.
i know how you feel, i dont know who owned my truck but i think it was a heavy set old grandpa, one it had the topper, two my drivers seat feals like i got rolled on by a steam rolleri hated my topper lol... it looked like a grandpa truck (weird that i bought it... FROM MY GRANDPA)
That does not look bad at all, i'd not worry about clear for now but to answer your question, yes you can get clear in a can.
