Need some tire purchase input please - 15 versus 16
Slim
Ontario, Canada
I am currently gearing up to do my spring lift install (SJ 2" coils and AALs). I am currently running stock 15x7 rims with small tires. The plan is obviously to go bigger. I have a set of 16x7 stock rims that I wanted to use for the new rubber, but .....
A local tire outfitter has both the 15" and 16" tires I am looking at. I can get either a 31x10.5x15 or a 265/70R16 (really close in diameter to the 31x10.5x15). There is only a $5/tire price difference. I'm not sure which I should go with. Price is not of any concern. Looks are not a top concern either. I am concerned with the performance of the tire - will be about 80-90% street use and the offroad use will be easy stuff.
I am inclined to believe that the 16" would be a "better" choice given the shorter sidewalls, which should provide less flex (better handling). Also, if I go with 16" rubber now I could always keep the 15" rims and get snow tires later (IF need be).
Any further thoughts or input of any kind on this?
PATIA!
265's are actually closer to 32's. What kind of tires are you looking at?
I like 15's because in the event you need a new tire or tires, they a very easy to come by and very well priced used. I know you said price is not an issue, so you may not care about this. I don't think the side wall on those tires would be different enough to notice a difference. That's just me though...
I haven't decided yet. The Canadian Tire chain up here has Goodyear, Cooper and Motomaster on sale, so weighing options and such.
According to my math the 265/70R16s have a calculated diameter of 30.6". Pretty sure i'm doing it right. Perhaps i'm not. Care to share? :)
Loud and clear. I don't mean to say that price isn't important because i'm certainly not rich. You have a good and valid point. Thanks for the reminder. :)
You're correct. I was thinking 265/75R16's, which are about 31.5's.
