mudwarrior
well like the title says has anyone else ran into a problem with burning up the computer.the truck is a 1988 ranger 2.9, 5 speed,4X4 and when i got it.it didnt run.well after some checkin i found the PCM burned up pin number 46 was burnt on the board.so i went to my local junkyard and found one put it in and hit the key and POW smoked that PCM
well i got a wiring diagram started checking wiring and found the someone cut the wires to the clutch engage switch and kind half ass twisted the wires together and by my wiring diagram that is on the pin 46 circuit if im correct.so i was wounderin if any body else has had that problem and if so how do i correctly bypass it.
thanks Travis
thanks Travis
