need some help
80shot ranger
Slater, IA
1998
200
im new to the site and i had a few questions. i want to do a suspension lift on my 99 4x4. i want to do shackles and an AAL in the rear. i would like to know how much lift that will give. i would also like to know how to level the front with that kind of rear lift. i think that cranking the torsion bars wouldnt give me quite what im looking for. any help will be appreciated.
I wouldn't go with AAL's unless you're looking for more load carrying capacity, they make the ride stiffer and reduces your flex... If you want to go anymore than what your torsion bars will twist up you need a diff drop kit or SAS...
http://www.therangerstation.com/forums/showthread.php?t=42452
Shackles and AAL will get you 2"-3", depending, but you cannot adjust the torsion bars that much to match the rear.
http://www.trsfabandoffroad.com/products/superlift_suspension.htm
If you just want 3" of lift to clear 33" tires and don't want to drop $1500, get a bodylift.
thanks for the input guys. ive still got my mind set on suspension. the info in the link was great. ill let you all know how it goes. thanks again
