jawbreaker877417
- May 23, 2013
- Automatic
'97 ranger 4.0 automatic 150k k&n intake lifted regular cab 4x4 tons of work dana 35 in front (if i remember correctly) warn manual hubs, auto transfer case, has optional front ABS, with a steering stabilizer or some sort of shock on the front axle. truck makes a noise exactly like a wheel bearing is gone in the front end, BUT this noise will shift sometimes it happens during hard(ish) left turns only, indicating passenger side, but sometimes during hard(ish) right turns only, any ideas??
(had a small-time mechanic take a look maybe 6 months ago, said he adjusted the adjustable wheel bearings, swapped out a tie rod, and an axle joint. also brought the truck elsewhere for a wheel alignment afterwards, perfect "steer ahead" according to the printout, still pulls hard to the right, hard. Not only that but i have to keep the steering wheel aimed slightly to the right and keep nudging it counter-clockwise to maintain a near-straight path. problem in the steering column?)
