Need Some help for a friend
86_cookiemonster
November '08 STOTM Winner
MTOTM Winner
My friend is working on a project for college where he is designing a crane and putting it in the bed of a 2010 ford f250 regular cab long bed. The current plan is to attach it to the frame using the same holes as the bed bolts. The problem is he needs to know some measurements and he asked me for help, and I am having trouble finding information.
he needs to know how far apart the bolts are.
*---------* what are the actual measurements between each bolt?
and the measurements of where they are located on the frame from either the bumper or the cab.
they are trying to build it in a 3d model. Any help on either the measurements or were i can find them would be great.
sorry if this isn't exactly clear, its kind of hard to put into words
well i dont have a new truck to measure the distance between the bolts...but you could saunter on down to the ford dealership with a tape measure...i would avoid measuring a random strangers truck in a parking lot, it is an excellent way to get shot.
good luck with the project but as a note..if you are designing a crane you would want to design it to be a universal fit into any truck, it would bolt to a plate that is mounted to the frame similar to a fifth wheel setup, that way there is enough room for it to rotate with out hitting the box, room for operater unless you are planning on in-cab controls, it would also be located centrally above the axle for weight distribution..
ya know, the more i think about it the more i say leave the stock bed bolts alone, its okay to drill holes in the floor of the bed, people do it all time, how about you look at real-world set-ups of truck-mounted cranes and then just downsize for use in a pickup. and make it universal, people that have a use for a crane drive dodges and chevy's too..good luck:icon_thumby:
