Need Schooling on Wheels
enjr44
Renton, WA
02 2X4; 08 FX4
I have 91 4X4, 4.0L I need info on what wheels will fit on it.
The truck currently has aftermarket wheels on it and they stick out beyond the fenders. I want to get rid of them and put more stock like Ranger wheels on it. I assume any pre 98' 4X4 Ranger wheels will fit (yes/no?).
I checked the tech section and still have several questions.
1. Will 15-7 inch 2X4 wheels fit on this truck or do they have to be off a 4X4? It came with 15-7 wheels originally and I would like to go back to that size.
2. If 2X4 wheels will fit, will any (earlier than 98') 15-7 inch wheels fit?
3. Same questions about putting Explorer wheels on my Ranger.
Thanks, Ed
Sounds like what you're looking for is a wheel with less backspacing.
2x4/4x4 shouldn't matter, just make sure to get a wheel with a 5x5.5 bolt pattern (I.E. any stock ranger/expo, and some jeeps). Do a quick google search on wheel backspacing, you'll find something to explain it ina more concise way than I could. Measure the backspacing on your current wheels, and make sure your new ones are an inch or two less.
Maybe someone could chime in with the stock wheels BS measurements?
I had a 1991 2wd and it had 5x4.5" lug spacing just like my 1998 4x4. The 1998 has 15" rims where the '91 had 14" rims. I do believe you're looking for 15x7 with a 5 on 4.5" lug spacing. I don't remember the backspacing measurement off hand but I'll see what I can find...
I have owned several BII's and Rangers and I do know that BII, Rangers and Explorers all have 5x4.5 bolt pattern. if I remember right...1998 and up 4x4 Ranger front wheels won’t work on 1983-1997 4x4 Rangers. Center hole area is a different size.
Do a search on the site. I know this has been brought up a number of times. Check the Tech area out.
Thanks guys,
I know about the 98 and up thing. I was mainly concerned about 2X4 and 4X4 thing.
Glad to know the Bronco/Explorer wheels will fit.
Ed
I have 2007 or 08 ranger sport rims on my 97....they fit just fine
Even used the 97 center caps
Some styles fit and some don't, it depends on the style of rim.
You can have a machine shop enlarge the holes to fit whatever centercap floats your boat and clear the front lockout though.
