BuckHunter
Hey, Guys new to the site. My problem is I had new upper and lower control arms installed at the dealership. When I got the truck back it sits higher in the front than before its level now. So I get under it looking it over and pulling measurements. The adjusting bolts on the torsion bars are exactly the same one-inch sticking out. The bump stops are exactly the same on clearance. But when I measure from the ground to fender well the passenger side is half-inch higher than the driver side. They marked the adjusting bolts with a yellow marker so they can put them back exactly where they were. what happened here. Also done away with the 2 piece passenger-side upper and went with the 1 piece. My fault should have taken measurements before doing the work now I don't know what the factory measurement was. I figured the dealership would pull measurements before and after. Any thoughts are greatly appreciated.
