merace19
- Sep 10, 2008
- Automatic
What the title says. I got a Limited slip in a explorer axle. Its 8.8. The LS seems a little weak and I want to tighten it up real tight if I can. I have read the write up in the tech section. I wish it had pictures of every thing inside the diff. Also where parts place carries the rebuild kits? And finally if I dont use the friction modifier but I will use synthetic oil, will the clutch pack destroy it self? Reason asked about not putting the friction modifier in is I want this ls to be as tight as possible. I dont want to have to weld it up due to issue with the case.
