galvan23@gmail.com
- Jan 7, 2011
The engine turns,but the truck would not start,well i replaced the fuel filter,the problem continued the same,mechanic told me its the fule pump,replaced fule pump and fule filter again,worked good for 2 weeks ran great just like new,after 2 weeks,same problem, agin replaced fuel pump,filter and clean out fule tank,again this time it lasted 16 days,again same problem,again they replaced fule pump,was good for 8 to 10 days,mechanic said its got to be the fuel pump manufacture again new pump and worked for 2 1/2 weeks,and again its back to the same problem,it starts sounds good if you give it gas slow it will pick up and sounds great,if you give it gas fast it spits and spuders and then no matter how much you step on the gas it does nothing but eventuley die,if you wait a min or two it might start again and does the same thing,last thing i did was replace the pump relay and its still the same,ive replaced 4 fule pumps and nothing,one relay,5 fule filters, i can hear the pump kick in when i turn the key then it stops and some times it will start the first try,but as soon as you give it gas it spits and spuders and dies again and again,if it starts and just leave it running it will stay running,until you give it gas.some times befor it quits running or was about to ,i will be going down the highway and the truck will just die and then if i pulled over and turn the key off and tried it again it will run good for 10 -15 miles with no problems but the eventually it will get so bad that it will just do it all the time, the next thing i replaced was the fpr,the problem its the same,now someone else told me to replace the mas air flow sensor what do you all think,need help
