need help
Leon44
or a schematic if you have one :blush:
Only 4 of my warning lights in my 87 ford ranger light on the dummy check and those are the battery, coolant temp, check oil and brake.
I took off the dash and there is a black wired in port 11 that has been clipped.
I've looked and there is no black wire in there that will connect to it. (Note: the owner before me had a roll cage installed and they probably did it.)
I thought it was a ground so i tried to connect it to ground but it did nothing.
After remove the fuse and plugging it back in to see what happens ive come to the conclusion that that black wire must go into the fuse box, but I dont wanna chance it if im wrong. Can any one help me? :dntknw:
