Need help!!!
Bowman89
So my truck starts when i turn on the electronics it doesnt wait for me to turn the key all the way to start the starter. I am not sure if the starter is still running while the engine is still on. Has anyone had this problem or know what it mite be?
Sent from my SM-G928P using Tapatalk
If the starter is still engaged? Trust me, you'll know LOL. My old bronco did that when the new solenoid fried a contact. (Right out of the box...bad part...BWD sucks for solenoids)
Sounds like a high pitched Weeeeeeeeeeee sound when it sticks on. (Engine will rotate at about 1200 RPM or so when the engine starts. Your starter turns at a fraction of that. If it sticks engaged? Your starter is really going to fly...)
I'd suggest pulling up a diagram of the starter circuit and doing some basic tests. The starter should never kick 'on' when you just turn the key to the 'on' position. This could be a stuck contact in the solenoid, bad ignition switch/contact, aftermarket remote starter gone bad, etc...
S-
