Need help
daveman3815
I have a 1995 Ranger STX that I put in a 2 inch lift. Now I have a problem with the front camber. Its adjusted as far as it will go. So I need to find a pair of offset ball joints. Does anyone know where I can Find these?
No such thing as offset balljoints. Just camber/caster adjusters that are installed over the top balljoint stud.
Actually there is such a thing. I know of the adjustable bushing, and they do make offset ball joints for just about everything but my Ranger.
Ok, let me rephrase Squatch's statement...
Ford was not dumb enough to use off-set ball joints. They saw that Jeep did it and said "That's a good enough reason to find a smarter idea."
the 4* full adjustable bushings will do the trick, Napa has them, don't remember the part number, the 1* bushing you have right now is never enough to do any good...
why dont you just go out and buy some more adjustable cambers? they only cost about 70 bucks and i know there are some out there that are +/- 5 degrees or more. which should be more than plenty for a 2inch lift.
Thanks for the advice. I actually work at NAPA and I know we have a 4* adjustable bushing.
