2.3L ('83-'97) Need help with this black wire with green stripe
Kansas City
MO - USA
Vehicle
Drive
Cannot find where it connects. Black with green stripe. Thanks! Found it. Oil pressure sensor I believe.
  • Need help with this black wire with green stripe
You have a "low oil level" light. That runs out to what looks like a float, on a white/pink wire.
You should have a oil pressure gauge, it runs out on a white/red. Ford has used that color for many years. The coolant gauge uses black/lightblue wire. These wire colors will fade over time, make sure it's not the coolant sensor.
Sorry to be so dense but the sensor at back of head I am thinking is coolant temp and I have white/red and the black /green or blue connected below that on the block which I am thinking is oil pressure. The white/red won't reach below the head. When I started it the oil pressure gauge never moved but temp did eventually. Thought I had them crossed but the one is too short to be crossed. Put a new head on this 2.3 for a friend so just trying to get it done. Not familiar with this thing. Thanks for the help.
