Need help with suspension issue!
rngr_dngr
What's up everyone. First off, let me say I've done a ton of research and couldn't find anything about my problem. I have an 01 ranger, lowered 3/5 with belltech 3" springs up front with Doetsch tech shocks. I replaced bumpstops with aftermarket pancake styles. So the problem is, even with aftermarket bumpstops I'm still sitting flat on the damn things, so I basically don't have a "suspension" at this point. Rides like total ass and is starting to cause back problems for me. So what, if anything can I do to get off these damn things? Without raising it or cutting and welding. Help me Tom Cruise!!!
you will more than likely have to check and make sure they sent you the right springs for your drive train combo and cab type, if correct then your looking at replacing the old springs and going to drop spindles, it would help if you could post a pic of your front suspension 98 and later are a little tuff to get right, there are other options But $$$$$$$ like upper and lower control arms
Idk if this would make a difference, but my sway bar end links are not straight up and down, they're kinda crooked. They are shorter than stock, so as I was bolting them on, I think it either pulled the control arm up some, or pulled the sway bar down
