techsvcs
- Aug 9, 2010
Alright so i have a 1987 ranger 2.9 4x4 manual trans. Could someone help me with this? How do i check to see if i am having rear end trouble without taking off the cover? i just noticed that when i take off or stop it feels like i am taking up some slack some where but there is no vibration or howling noise i jacked up the rear tires and i can move both tires in and out about a 1/2 inc or so and i also noticed that when i spin 1 tire there is a little bit of time before the other tire starts to rotate also when i move the drive shaft up and down there is a little play or movement but i can't move the shaft in and out. does it sound like anything is worn out or does it sound normal or could something else be the problem? Front breaks and wheel bearings are in great shape and i am only using my rear wheel drive not my front. If rear diff is the problem is it expensive to repair and is it something i can tackle my self?
