fireguy12117
i finally get a rebuilt motor installed and running on the 93, however it doesnt run very well.
right now it has a rough idle around 800rpm and when ive let it sit long enough it bellows white exhaust and smells i dunno, rich i guess.
i think i might have an exhaust leak on the pass. side where the manifold meets the y pipe. i had to rig up a clamp and i need two people to really reef it down. otherwise, i dont have any check engine lights to go on. i dont have any plugs dangling, ive got oil pressure, fuel, and the spark order seems to be correct. i pulled the TPS and got a CEL to come on, so the bulbs not burned.
the gas is 8-10months old, and its a newly rebuilt block.
i guess tomorrow ill see if im missing coolant to see if i have coolant getting into the cylinders. whats the other way to confirm wether im burning coolant? what are signs of white smelly exhaust?
i try to drop it in gear and it starts sputtering and back firing and wanting to stall....need some help.
