Need help with clutch!
Tennessee
i have a 90 ranger with 5 speed and when it gets around 40 degrees or below i lose clutch fluid and have no clutch gotta put flluid back in every day just wonderin if anybody else has had this problem, thanks
sounds like you need a new slave, master or clutch line.
Id start with bleeding the system, and the consider a new master or slave. If you do the slave, its a good time to replace your clutch.
ok thanks i was gonna try replacin everthing cause i think my throw out bearing is fixin to go out
