Need help with Bronco 2
booger
Ok were to start, before I put in a used 92 ranger 2.9l motor in the B2 4x4 5 speed, would drive down the road with seem like just a worn out clutch, seem as if it just didn't have any go to it and would barley grab right at the end of letting off the clutch, and just assumed it was the motor which was completely shot, when I installed the new motor in I put in a new clutch kit and check the flywheel and it seemed fine, cranked it up and the new motor ran great, went to put it in gear and it wouldn't move, clutch seems to disengage fine and when I put it on the lift and in gear the front and rear drive shafts would barley turn in 2wd and 4wd, my friend thinks it could be the flywheel or some spacing issues with the flywheel, it doesn't make any noise when cranking or running or when put into gear and shift in and out of other gears fine. I don't know if it could be shift forks or what I really don't mind pulling the transmission back out but it would save a lot of hassle if someone knew of the problem and could steer me in the right direction if the flywheel wasn't the case...Thanks guys
Sounds like you have a bad transfer case that needs to be replaced or rebuilt.
And make sure that you have all the gears in the trans. If you lose a gear it might move a little bit but then nothing happens. but to me it sounds more like the transfer case not doing its job do to something wrong with it.
Put it in 2nd and see if it does the same thing if it does then most likely it is the transfer case.
