Need help with acceleration!
Kelcita
I'm new here and not sure where to post this, so move it if you like.
I'm 16 years old, and my dad let me have his Ford Ranger 2003 truck to drive around. I was driving my sister to work, when I hit a huge pot hole. I pulled out of the parking lot and tried to accelerate to keep up with traffic, but the truck wouldn't go as fast as it usually does. It takes a while for it to reach 40 mph. It's not jerky, so I don't think its the sparks plugs... But if I floor it, it doesn't change the speed at all than it would if I gently push down on it. Brakes are the same. What could be the problem??:icon_confused:
there is fuel pump shut off that will turn off your fuel pump in a accident what the car thinks is an accident "pot hole". Look in your owners manuel and it will tell you how to reset it. Its usually up near the dash and floor meet, under the carpet.
i dont think the inertia switch is the problem with that its either on or off, not slow
bad tank a gas maybe? run some sea foam through the motor, that stuff works really well, cleans off the injectors good. Your gas milage will be a little worse at first.
What tire(s) did you hit the pot hole with?
Did it feel like you bottomed it out?
tough call
Just a guess, but it may be possible that a rock or something may have gotten wedged in the brakes. Or possibly lodged the brake pad against the rotor. Does the car pull left or right now? Or possibly the alignment got so screwed up that it is hindering acceleration. Again, this would probably cause an alignment pull.
If it's a 4-banger you could have caused the timing belt to jump a few teeth when you jarred it that hard. Not likely, but the cam timing being a few teeth off would cause the problems you described. I've had mine jump about 20 degrees when I stalled it hard.
Check the exhaust system. If it bottomed out you may have crushed the converter or tailpipe flat.
It may have caused the inside of the catalytic convertor to come apart and plug up the convertor. If it runs and gets hot the convertor can actually start glowing red. With the exhaust plugged up the truck wont go.
Just another suggestion.
+1
I had this happen with my truck. The cat clogged and it would hardly go past 2700 RPM and took forever to get up to speed. A good hammer fixed it to get it to the shop
代写论文
毕业论文100通过 QQ357500023 大型留学生专业英语代写论文机构,10多年的悠久历史(中国历史最长的留学生论文...商业英语毕业论文、会计毕业 留学生论文网100%通过 QQ357500023 大型留学生专业英语代写论文机构,10多年的悠久历史(中国历史最长的留学生论文...加拿大,美国,新加坡 代写论文 发表论文 代写论文 论文发表 首页 免费论文 English 首页 代写论文发表论文...· 诚聘有代写发能力的工作团队 · 长期诚聘执笔作者 · 长期诚聘各大高校独家代理 因本站业务量猛增,特招聘兼职写作人员 代写论文有关知识 我们的网站是一个具有良好信誉、专业从事论文代写与发表的网站。...代写论文服务网由全国重点院校高水平的博士硕士、部分在职科研人员和在职教师组成的一个团体,为您进行论文代写的服务
