rangerguy351
- Oct 6, 2009
- 87 ranger
- Automatic
well i got into the front of the engine to do some preventive maintenance replace the surpintene belt the water out let spout.. well i looked at the timing belt and it looked like it was ready to go... soo i took the power steering bracket off pulled the harmonic balancer took old one off i set the crank shaft on tdc with the deg. gauge on the pully cover. aligned the triangle with the other one on the cam and then the oil pump drive i aligned that also prolly not critical beings its not a distributor engine.. well i rolled it over by hand just to make sure no valves would hit or anyhitng started it up run great.. well get going down the road 1st gear up to 15 hit 2nd gear kinda let it lug its self along and she jerks bad... not like a regular to high a gear and going to slow jerk it really goes back and forth bad.. shift down and run the gear higher and theirs no problem dosent do it.... and it did not do this b4.. b4 youy could ride 4th gear doing 25-30.. just kinda chug along... so did i do something wrong could the timing be off i noticed their a a spot on the crank sensor that has a tooth missing off from it (not broke) and that is supost to be a 36o mark...? well i seen that on a 4.0 diagram is this something i missed....so i guess im looking for a from start to end what is the exact steps... not just mark the belt and hopefully put it back on but the line this triangle up with this one and the crank up with the cover.. i just dont know.. if someone could help me that would be great thanks
