When you think you are on the compression stroke, look down at the crankshaft pully and see if the pointer is any where near the TDC Top Dead Center mark on the pully. It is pretty easy to go past the mark just by feeling it with your thumb. Turn the crankshaft pully with a 1/2 in. drive ratchet and the soket that fits the pully bolt. Adjust that so the pointer is on the TDC mark. Pull the cap on the distr. and see where the rotor is pointed. I should be pointing at or near the No. 1 plug wire fits in your cap. When all this is done, it should start if thats your problem. If it does, put it all back together and put a timeing light on it. Losen your distributor a little (just enouf to turn it with a little pressure) and set your timeing at 10 degrees BTC (before top dead center) and you should be wheelin. Good luck,,hope this helps.
