ckblum
- Feb 21, 2008
Me and my Dad just swapped in a 92 2.9 into my 87 Ranger. We used the 87 harness and disconnected and plugged off the EGR because that's how it was on the 92. The EGR isnt the problem because it ran the same before and after to took it out.
Here is the problem, which I think might be the fuel filter or maybe the main fuel pump (dual tank setup, two filters also). The truck would start up fine and run like normal, it would run until we shut it off, once it was shut off we could not start it back up again. We switched to the front tank and it started up again and would run till we turned it off but it would not start up again after. If we leave it sitting for a while, a few hours, it sometimes works again. The guy at Lordco said it could be a fuel pump (not worried because I have a whole other 88 parts truck), sometimes they start acting up when they get old and used, plus it is right by the exhaust so that could explain why it won't start once it gets warm. Any other ideas?
