Hey everyone, new to the Ranger club!
Picked up a non-running 97 2.3 with 83k on it a week ago and have been working on getting it running. Ended up having 5 year old gas in the tank (about 7 gallons) so I dropped the tank, drained it, and cleaned out the...sludge. From there, I replaced the fuel sending unit & fuel filter & got it to start.
It still wasn't running great, so I went on the hunt for some vacuum leaks & found a cracked line on the heater core bypass, a PCV valve that wasn't in its grommet, and the vac line connected to the hardline through a gap in the manifold was rotten. The fuel pressure regulator was also leaking fuel & was replaced. Since doing all that, it is running better but still something is off.
In THIS VIDEO you can see the reading of a vac gauge connected to the intake manifold (I used a T & had the FPR hooked into vacuum as well) & it has some slight...pulsing? not sure what to call it, at idle & really bogs down after 3200rpm.
Other things I have changed out is Sparkplugs (NGK), wires (motocraft), cleaned the MAF, and then ended up getting a new one as well. Cleaned the IAC valve & also "backflushed" the injectors by running rubbing alcohol through them backwards.
Other tests that I've done include spraying all the vac connections I could see with carb cleaner to hopefully hear a change in engine RPM (no dice), taking the temperature of the cat to see if it was clogged - it was about 100 degrees hotter at the back, so seemed pretty normal (I think it was about 550 at the front & 650 at the back. didn't write it down) and I did a compression test - all 4 cylinders had over 200psi of compression (213, 230, 240, 230 respectively). Pulled the wires off the coil pack to look at the spark - all of them looked pretty strong. Checked O2 sensors through OBDII port - Upstream o2 sensor does change rapidly, and the downstream was reading a relatively constant .7-.8v. I also cracked one side of the cat connection to the manifold to reduce pressure & it was more or less the same. Also, the EGR valve DOES hold a vacuum & the supply hose increases vacuum as RPMs rise.
I am honestly not sure where to go from here - The exhaust does smell like the truck is running rich & when I pulled the plugs for the compression test, they were a dry black, with white residue on the ground electrode. It is NOT throwing any codes. Any help would be GREATLY appreciated.
