BroncoLover12
Hello all,
I recently posted about engine idling rought, idling at full throttle, etc.. Got that fixed, seemed to be mainly the IACV, but probably some of the other things I fixed as well. Thanks for all who helped
I now am dealing with HEAVY sputtering.
I noticed this hose from my air filter area to the intake manifold (I think) under the battery looks like it is damaged, and needs replaced. I am not able to find the name or part number for this - Could someone let me know the name of this item and where to buy if possible? Would this be cause of sputtering? Is it important?
I also noticed I was missing a bolt here near oil pan. Anyone know what size / type by chance?
Last thing, I went to replace TPS Throttle Position Sensor, and could not get the old one to come apart from the clip... Any advice on getting that off?
Sorry if this is dumb questions, I spent the time to look for this info on the web but had little to no luck, so I very much appreciate any help...
For my sputtering - Replaced fuel filter, checked fuel pump looked fine, replacing O2 sensor soon as it looked rough and I had hole in muffler that I patched. I need to check fuel pressure still, anything else?
I have also seen a lot of stuff about "Timing" and correct position of the throttle screw. These things I am new to, does anyone have an easy method they could maybe walk me through?
