Need help identifying lights
mywhip
Ohio
I believe these are 194 bulbs, but i plugged regular 194 bulbs into where they go, and it didn't put out enough power like these ones do..so i need some help identifying what they are.
Those look like Putco LED 194 bulbs. Basically an LED is a little diode that can emit much more light for its size than an equivalent filament bulb. I'm guessing they are Putco brand by the casing colour/shape.
My bad, i put LED 194 bulbs in there, and it didn't put out light like these ones do, at all.
Any auto parts/accessory place should have them. We even have them at the dealership.
As for those one being bright they do have a very unique lens on them, most just have clear plastic covering the diode, if anything at all.
I thik he is saying the LED's didn't put out the light he was hoping they would, compared to the incadecent ones.
I found with LED bulbs it really matters what pattern and how namy you get. Like for my truck i got the superbrightled 4x bulbs with the widest spread I could get which I think was like 90 degrees and they show up great. Some people have had luck with the single bulbs and 180 degree patterns in older trucks.
They go into my headlights.
My problem is : I hooked in a green LED bulb in its place, but it didn't put out nearly as much light as this one does. I need to fight the exact match to this one, but in amber.
also superlumination.com...they have LED's to fit every socket in the world. and are pretty well priced.
Nobody seems to understand what i am asking, so ill try to reword it.
It is a 194 LED bulb, i am aware of that. However, when i hook in a LED light i had in my gauge cluster from a previous car, it is only half as powerful..so there has to be something special about these particular LED bulbs.
No..i need to know if there is something different about these LED bulbs, compared to those that i have ordered off of superbrightleds.com
Well there is, every company makes different lights, just like if you get Phillips bulbs for your truck and they are way brighter then the old GE bulbs in there. The light output is just different, different manufactures have different specifications to others.
