Need Help, finishing a 3.0 rebuild
I've misplaced which lines hooks up on the backside of the intake manifold. On he backside there are two ports one with a 90deg bend, which goes to the brake booster (I believe), and there is one beside it that comes out straight. and then I have the PCV.
What I can't remember is which one takes this vacuum hose arrangement, to best describe it, it has three small hoses that is in a 90deg rubber boot. Once I have which one that vac line hooks up to, then I just need to know where to find the other line to hook it back into its proper place.
What Vacuum hose diagrams I have seen, have only served to confuse me, I'm more used to reading schematics for Air Conditioners and Furnances. Some of it I have figured out, but some of it is escaping me.
Thanks for trying, I don't live in Michigan.
But I did end up finding my missing hose to the PCV valve, it was easy to miss becasue of its location under the upper intake manifold.
Got everything hooked up, put the key in and tried to start it...........dead battery, did a jump start and it fired right up with no problems and it ran smooth. So I did get the coolant topped off and got the last of the air out, gonna give it a little road test tomorrow.
