I need to replace my leaf spring and I need to change the ubolts also. I cannot figure out the size of them auto order new ones. I know they are flat bottom tho
It depends on which axle you have. Look through this in the tech library, select the axle you have and look up the tube diameter. That will tell you the size you need.
Rear Axles Used: Ford 7.5-Inch Axle: 1983-2011 Ford Ranger’s without a 4.0L V6 came with the Ford 7.5-Inch Axle. 1998-2011 Ford Ranger Super Cab 4×4’s are frequently equipped with 8.8-Inch axles regardless of engine size. Click HERE for more Ford … Continued
For
