Need Help Fast
beckalb95
So I have an 88 bronco 2 with a 2.9l and I was on the way to work this morning and it just decided to shut off and not start back up, it smelt like something burnt up on the inside but I couldn't find where it was coming from so I checks out the relays under the hood and it kind of smelt like it was coming from one of them, I've had problems with I believe the ECM relay and I could jump the yellow and red wire and it would start, I did that and it didn't start still, so I was wondering if there is any other relay or something simple that could all of a sudden go out while I'm driving that would make it not start?
Yea but if it was the fuel pump wouldn't it spit and sputter and then shut off? Because when I was driving it just completely stopped and shut off, but I will check out the fuel pump relay when I get off work
will it crank? does it click? or does it do nothing when you turn the key?
turn the key on you should hear the fuel pump cycle without fuel pressure it will not even sputter.
It'll still turn over, and when I turn the key on I hear the pressure pump but I never could even hear the fuel pump before
have you ever replaced the tfi module
Weres the tofu module? And I did smell something burnt but I could find where it was coming from
Don't they have two fuel pumps? My buddy's ranger would spit and sputter because one wasn't enough to run, but enough to try.
P.S. you could hear the one pump running. It was loud, the tank prime pump wasn't working. It would actually start and run if you let it sit for awhile, but would sputter then die.
If it has the fuel pump under the drivers seat on the frame yes it is a two pump system. Depress the schrader valve on the fuel rail to check for fuel pressure.
Ok so I found out that it is getting fuel just not spark, so I checked out which I think is the eec or ecm relay on the passenger side and the fuseable link on the double yellow wire blew. So I replaced the fuseable link with a new wire and fuse and it blew a new fuse instantly, after blowing 3 fuses I stopped. So I no I have to have a short somewhere, and was wondering where it would be, or where the wire goes. I think it might be the computer brain thingy under the glovebox because I did smell something burn up when it shutoff, but I'm not sure.
This one shows the yellow wire.
http://www.therangerstation.com/tec...es/Diagrams_ElectronciEngControls2_9_1of3.JPG
http://www.therangerstation.com/tec...es/Diagrams_ElectronciEngControls2_9_2of3.JPG
http://www.therangerstation.com/tec...es/Diagrams_ElectronciEngControls2_9_3of3.JPG
Suggest you follow the yellow wire and disconnect the PCM, turn the key on, see if the fuse still blows.
It would be helpful to know WHICH fuse blows. If it's that 30A #8 in that first diagram, it could be anything on the Red wire if the fuse blows when the key is turned to Run. If so, disconnect all the parts connected to the red wire and hook them up one at a time until the fuse blows.
In any case, it would be wise to look at every segment of the harnesses for areas where they could chafe against any metal. If it stunk by the PCM, start looking around there. Look for any water intrusion.
