- Jun 15, 2009
- Arcadia, Fl
- Automatic
You ride at 50 psi for a ranger? I thought no matter load range of tire 35 was good. Did you do 50 because of tire, or because it actually rides better at that psi? I'd be worried my tires would explode on highway...
The door jamb sticker on my 07 says Ford recommends 30 psi and the tire says 35 max. I run them at 31 psi cold.
It doesn't matter what the max inflation pressure says on the tire, always run real close to what Ford recommends unless you are loading the truck down to the max and beyond......50 psi would make a Ranger ride rough enough to bruise balls or dent the wheels over a moderate bump. Increased tire inflation pressures are ONLY for load carrying capacity....if you run empty, 30-32 should be best.
I would run tires made in Canada or the USA only, the Asian tires do not get my recommendation regardless of how cheap they are.
