Need Help ASAP
sdfishman
San Diego
I had a mechanic working on my truck earlier and he broke a couple things. I need to replace my fan clutch.. He broke a sensor and nicked my water pump pulley. What s this sensor and can I file down the nick on the water pump pulley? Here's a few pics.
I'll try the emery cloth on the pulley. Still pretty worries about the sensor.. anyone know what it is or is there a PDF online for the 4.0 motor?
hi, from looking at the pic it looks to me like it is the water temp sending unit. here is a page and web site that is linked to in another area of TRS. this will take you to the section for thermostats. the piece in question looks like it is sitting next to the thermostat pipe on the intake manifold. hope this may help or get you on the right track
http://arrc.epnet.com/autoasp/framerq.asp
ooops the sign in is auto and pass is auto..... after you sign in go to car repair and navigate your way around to what year make.....
Thanks Angie. I tried to navigate threw that site but I couldn't find anything pics....
Its the sensor. It still looks connected but the plastic housing is cracked.. Wires are exposed. Would it be ok to run it like this until I make a junkyard run?
Alright after a long day. I replaced the fan clutch.. 2 blocks into the drive "IT"S BACK". Still squeaking.. I have replaced almost everything. What next???? Idler pulley/tensioner pulley/clutch fan/alternator/serpentine belt. I'm running out of options..
Ok another day.. I had a mechanic come out and look at the truck today.. He said it was the water pump.. I replaced it. I thought it would be done.. "FU#K NO".. Its even louder.. Anyone have any ideas? I a lot $400 in the hole and the truck is F#CKen loud..
Total Replaced..
Serpentine Belt
Tentioner pulley
Idler Pulley
Clutch fan
water pump
alternator
Update. Lots of money later it turned out to be a defective serpentine belt..
