NEED HELP ASAP Headlights flashing on and off
Ranger D
Canada
Need help , this morning when i parked my truck to wait for my ride to work.....ignition off ...headlight switch off setting there a couple of minutes in the dark when all of a sudden my headlights started coming on ; first dim ; then brighter ; then flashing ; then they went out for a minute or so then back on ..had to remove battery cable to make sure my truck would start tonight .
It started fine and the lights aren't acting up so far since i came home .
Any help greatly appreciated...i called my mechanic , he said it sounded like the headlight switch but may also be the DRL module ; anyone know where this might be located , i forgot to ask the mechanic .
Tks D.
1997 Ranger 4wd 4.0 5spd
Lights
Turn signal switch. Believe it or not, Ford ran a wire through the stalk. Happened to mine.
