need help 2.8 with offenhauser intake need thermostat part number
Sgt.ranger
indianapolis
Hello I need a part number for a thermostat for my 83 ranger it has the 2 piece offenhauser intake and the stock 2.8 thermostat does not fit. Or if anyone happens to know of a vehicle year and engine size that would work is greatly appreciated thanks sgt.ranger
It may just use one in the lower hose.
I have heard conflicting reports about if the older ones had one in both locations at the same time or not. My '85 only had one on top where it god intended t-stats to be but the earlier ones had one down below.
EDIT:
I ran into this in the 2.8 section of the tech library:
OFFY 4bbl / Holley 390 cfm - We recommend this manifold carb combination for street driving. A popular choice for the 2.8 Bronco/Ranger. It will perform well on a stock or modified engine. It is easy bolt-on horsepower that still gives good gas mileage. Bronco & Ranger require a special thermostat / waterneck housing # 6278.
Part Number Description
6110 Offy 4bbl Manifold
6239 390cfm 4bbl Carb
6278 Thermostat Housing
http://www.therangerstation.com/tech_library/2_8L_Performance.shtml
With the offy intake you'll need to run the lower thermostat location. Even with the special water neck the stock t-stat won't fit up there.
