Need Airbag Wiring Schematic
mobile,al.
1984
maintain to work as advertised
Hello, I am trouble shooting a airbag code 52. I know it means the backup power supply voltage is low or no voltage. I have checked all the fuses and they are good. I had the battery disconnected for a day while working on the engine and that is when the code showed up. I need a wiring schematic for the airbag system on a 1997 ranger to trace the wiring and check for voltage and continuity. Please help if you can.
Thank You in advance for any help you can give. :annoyed:
why not clear code to see if it is ok or not? as you said you did have battery disconnected
I do not know how to reset it. My OBD scanner will not do air bags. I have not resolved the issue yet. I forgot to mention the fact that I had the battery disconnected because I had the wiring harness plugs at the firewall disconnected. That's why I want wiring diagram to chase the wires.
