exigent
- May 13, 2008
- Age
- 45
I have a 98 2.5 5spd with the 7.5 3.73 gear and it shot itself to pieces today. I posted once before about wanting to upgrade to a lsd and you guys provided some good options. Problem is now the diff is shot and I have to do something tomorrow. Budget is rather limited... The cross pin inside the diff sheared off on one side. Strangely enough, I was able to make the 20 mile drive home after this happened. I couldn't believe my luck when I removed the cover and saw the pin chewed up.
Anyways, I see I can get a traction loc for about $200 on ebay. I am also pursueing an explorer 8.8 with same gears and disc brakes... for $200 also. I understand the process needed to fit the 8.8.
I know my way around the garage, I've rebuilt motors and transmissions manual and auto. I have some good measuring tools and the like... I simply have never rebuilt a rear end. I know nothing of setting backlash pinion depth and whatever else Ive read about today. That said, given good instructions I can do the job. I have a press if needed(?) and I cant imagine its much more difficult then a 5spd rebuild... but Id apreciate some advice. Should I just get the explorer axle or should I go the traction loc route. I don't off road the truck at all. It is used for utility work (high miles, LOTS of stop and go). I live in MI and the snow last year got me stuck too many times. Given those two options what do you guys think I should do. Or perhaps a third option. Either way if there is a guide to installing a new complete diff could you please post the link?
