Need a 1988 Ford Ranger Service Manual!
lakers1125
Does anyone have the full service manual in .pdf form that they can pm me or something? Thanks.
Advance Auto or your local parts house.
Haynes manual or Chiltons. Both are decent resources. Plus most DYI'ers don't have a computer in the garage. The paper copy is handy.
S-
I don't have a PDF but I do own the manual. Anything in particular? I can try to get pics and post it up or try to scan in the section you need.
I might be able to just tell you what you need to know. What are you trying to do?
Change a window motor.
That is easy. I don't need a manual for that. Just take off the door panel and look at the unit see how it is hooked up and put the new one on. Takes about 20 min. to do it.
If the motor is original, and has not been changed in the past , you will need to look for the 2 dimples that need to be drilled out to gain access to the 2 8mm. bolts attaching the motor to the regulator.
