The wet hand only assists in proving his point. Once the blade rips into the finger and comes into contact with blood, it would shut off... A big cut is an improvement over a lost finger. I understand that, I even mentioned it in my post
Also, the bead of sweat thing wouldn't work. It works on your body, because the current enters your body and dissipates as it tries to ground itself. The bead of sweat doesn't ground anything, unless it lands in the perfect spot at the base of the blade or something like that. Lets say you're sawing something, resting your hands on the wood you're cutting and your shoes are keeping you from grounding out, and you're not touching anything else. Seems a little hard to differentiate your finger from a bead of sweat in this scenario, since neither is grounded. So either the sweat would trigger the device, or your finger would not. Do you wanna find out the hard way which one it is?
I could see this technology having a very good use, in places like high school wood shops. That being said, the fact it is so damaging to itself means only the most safety-conscious workplaces would ever install these. Yea', the kids would start putting their fingers into the blades being jackasses like teenagers like to do, and cost the school lots of money to replace the damaged components and god forbid the device fails to operate for whatever reason and the kid loses a finger
