BigTirez
- Dec 10, 2007
- Age
- 54
I have a 84 ranger 2.8L with (I assume) a Toyo Koygo 5 speed. The shifter handle floats all around the place even when in gear. I read the tech section about the shifter bushings. Is there a similar fix for my 84? It is so sloppy that it actually gets lost in 5th....if you don't pull the shifter towards the driver as you shift up out of 5th it just floats around all over the place and won't come out of gear until you find the lucky spot.
