2.3L ('83-'97) Mystery sensor
DandysRanger
North of Atlanta
If you didn't build it; it's not really yours
Can anyone identify this sensor? It screws into a pocket in the intake but is not exposed to any vacuum or water. I can't find the part number in the Google machine. This is on a 1985 F.I. 2.3L
the big flat mating surface is usually a knock sensor.
that's my guess and I'm not going to admit to anything.
That's just about the only sensor that doesn't touch coolant, air or oil.
I would also guess Knock Sensor
What color are the two wires?
Yellow/red was Knock Sensor
The two wires are Green and Black w/white stripe
Black/white stripe was common ground for most sensors pre-1990
Solid Green could be knock sensor as I don't see that color used on any other sensor, it would go to pin 23 on computer
It also looks like older Ford Knock sensor: https://m.media-amazon.com/images/I/41soHgAzLiL._SX425_.jpg
old part number was E3AZ-12A699-A 1983 number
Later part number F0TZ-12A699-A 1990 number
You can test knock sensor with engine running
Use a metal tool and tap any metal part of running engine, RPM should react with each "tap" depending on the part of engine being "tapped" needs to be a good sharp "tap"
