Bronclow2
- Mar 23, 2009
- Automatic
The problem began with intermitant power loss, gradually getting worse. Now the truck is absolutly undrivable. I am at the end of my rope and need Help.
The truck idles OK, never stalls but fails to make any power at any throttle position. When it is first started it runs fine, and then less than a minute later is is compleely worthless. It is 1993 Ranger 4.0L Automatic.
Beginning with the basics I check fuel pressure, it was poor, so changed the pump and regulator. X
The a basic tune-up,Replaced plugs and wires. XX
it idles better. but Still makes NO Power.
I moved on to sensor testing, MAF and TPS result Good.
I Replaced the MAF (because I had one), Crank sens, Coil, and Ignition module. XXX
Now having good ignition and fuel, I look toward controls. I am now getting really deep over my head.
I pulled the injector plugs to compare bank 1 vs bank 2. Bank 2 exibited the problem much worse, so I tapped bank one in to its output. (1 output firing all 6 injectors) it made a differance but still not drivable. I rigged up a switch to open the injectors so that I could atleast narrow my focus. SO, when the truck is stumbling opening the injectors makes it take off like a rocket ship. this verifies that the injectors are not being controlled properly.
So where do I go from here? The ECM is far too expensive to take a gamble with; my experience with electronics is they work or don't work, no in the middle.
So the questions for the smart kids in the class is:
1) What does the ecm use for a trigger to fire the injectors?
2) What inputs are the "critical" ones : crank position(rpm), MAF and TPS?
3) what tests can I perform to confirm or dismiss an ECM issue?
So the reason I refered to this as Mystery Ranger Death Syndrome is that this is the third ranger I've had with a similar power loss issue that I can not fix.
The other 2 were both '87 2.9L Manual. I Replaced everything on them including wireharness and ECM no fix. Scrapped 1, used the other for parts.
