- Apr 8, 2008
- 4.0L
- Automatic
Permatex® Medium Strength Threadlocker BLUE
Permatex® High Performance Thread Sealant
Permatex® Super High Tack™ Gasket Sealant
Permatex® High-Temp Red RTV Silicone Gasket
Which of these should I be making use of on this water pump gasket? From reading the Permatex website, looks like I could use either the threadlocker blue or thread sealant on the bolts, and probably the gasket sealant on the paper gasket. Thoughts?
As for the heads... they were just tested at the machine shop. The chance they are warped or cracked, is probably on the order of 0.01%. It is not likely that the head gasket is bad either, since it is brand new, and I followed the proper procedure to install everything. What is apparent, however, is that I can't hold a water pump gasket. Now, the gasket on the pump was NOT BLOWN before I started messing with it. In all likelyhood, it would appear I AM FUCKING IT UP. So please, HELP ME GET THIS DAMN WATER PUMP GASKET ON PROPERLY. Once that is addressed, and if I still have problems, I'll look at other things.
Don't get me wrong, I appreciate the posts, but I don't really need posts about my heads and head gaskets, when they are brand new! There is no sign of water in the oil. The coolant that was dumping out the side of the engine, is no longer leaking there. That tells me the head gasket was the cause of that problem. The truck isn't showing signs of oil in the water either.
For now, I REALLY just want to get this water pump on properly. That is all. Once accomplished, I can look at other things. And it is not the factory radiator cap. I have a Stant pressure release type cap on there, that is only about 2 years old. I realize it COULD be bad, but again, everything is pointing to me being a dumbass when putting the water pump on.
