Freshmeat
Just want a "second set of eyes" if you don't mind. I didn't put this specifically under tech because it's still up for debate how it will end up.
I'm about to completely redo my suspension. 2" lift on 34s looks awesome, but I hate having to go WOT just to clear all the breakovers. Here's the parts list:
4" drop axle pivot brackets
5.5" coil springs
Drop pitman arm
Extended radius arms (12" - 15")
Extended brake lines
Either custom or F150 radius arm brackets
F250 shock brackets
No clue what bumpstops to run
The plan is to go 5.5" up front and SOA in the rear.
Front: Superlift uses the 4" brackets for both the 4" and 5.5" kits so I figure it'd just set the geometry like a 2" lift without brackets. I'm going with used parts wherever possible. I'm slowly gathering parts for a SAS so I don't want to spend too much on this stage of the process. Going used I should be able to recuperate most of the investment by reselling. I intend to extend a spare set of stock radius arms by 12-15" as needed and will allow for camber correction the best I can when they're built. Also, I have F250 shock brackets to add for a little extra flex while I'm already tearing into things. I was given a part number for some 26" brake lines, which I'd imagine would suffice. I genuinely don't have a clue how I'll set up my bumpstops- any suggestions on that?
Rear: I'll grab a second gen 8.8 and SOA it. I'm going to have the shop who built my bumper add shock studs toward the bottom of the axle, as well as build an upper shock crossmember that will double as a mounting point for my OBA tank to keep it out of the cargo area. I don't know what to do for a rear brake line, but the bump stops should be simple to build.
Another idea while I have the rear axle out is to eliminate the center console for a hand brake lever, so I can control the parking brake easily in the event of a tight maneuver on an incline.
I think that covers it- is there anything I'm forgetting? Any suggestions on what I can do differently? Will my stock driveshafts be okay at this amount of lift?
Thanks for any advice, guys- I'm ready to make this thing a little taller!
5.5" coil springs
Drop pitman arm
F250 shock brackets
