compleckz
little synopsis, about 2 months ago i broke both left front axles, and popped a cap off a joint on the right side. this is with 760x's and full clips, so on my spare set of axles, i now have 760x's, stock clips, tacked caps.. and its held so far.
not only did i break both left axle ears, i broke the inner off at the splines.
i had to pull the beam/diff, pull the carrier and take the lockright apart to get the chunk out.. so much for a 2hr axle swap/wheelbearing repack job.
after i got it back together i decided to take a rip thru my backyard.. i was feeling a little bulletproof, so i didnt air down or anything, and the 24"+ of semi hard snow gave way and i ttb plowed myself stuck:
then after i dug myself out, i decided to do some poser flex, and test to see if the axles were rubbing anywhere.
then the next day, another snow stuck..
then a few days later i was messing around on the front lawn (im a huge poser).. and eventually got stuck, and my girlfriend pulled me out (again) with her Cherokee, i just needed a little tug.. i get stuck so much, its not embarrassing anymore. i blame bfg ats.
i think there was another snow stuck in there that no one bothered to take pics of..
then today i came home from class and went and messed around further up on the hill behind my house.. and of course:
got winch? nope. i dug out the front axle, and then tried to move the truck, and the tire dug down another 8".. if u compare the front shots of the truck, u can see how much deeper it dug on the 2nd try, look at the left front tire.... so im gonna try to pull it out with a few come-alongs tomorrow after class.
so yea its time to get some M/Ts again, i wore my old ones out pretty much, and got these bfg ats for less than half of new, and figured they'd be good for winter, and they were great on road in the snow.. but thats abouuuuut it.
also the axles have held up so far with the caps tacked, so cross your fingers for me.
