Bapfoutz
- Mar 25, 2015
- Automatic
so after I replaced head gasket and all the seals truck wouldn't start. So I did fuel test and it was 36 psi. Then did compression test
cylinder 1 - 40 psi
Cylinder 2 - 55 psi
Cylinder 3 - 150 psi
Cylinder 4 - 120 psi
Cylinder 5 -145 psi
Cylinder 6 - 110 psi
None of them are leaking air, so does it mean 1 and 2 the rocker arms are not torqued all the way or does it mean the valves are sticking? And cylinder 6 is alittle lower, any ideas for the three compressions?
cylinder 1 - 40 psi
Cylinder 2 - 55 psi
Cylinder 5 -145 psi
