my car is bent
kr.ppoo
korea
hi bro
The driver's seat has sunk
Replaced left and right shock absorbers
What parts do I need to replace?
Like this?
Cause.... if it's bent like that, probably not going to be able to fix it.
Translated to english per google
Hi
Tengjiaaaaaaaaaaaa
what...
더 많은 정보가 필요합니다
deo manh-eun jeongboga pil-yohabnida
No problem when driving
But I don't like it when I look at it
Sure its not the way its parked?
Maybe you need new driver seat.
It's called 'the ranger lean' and they all do it to some extent. Simply put, there's more weight on that side of the vehicle than the other.. so they all sag a little more on that side over time.
As Blmpkin said, this is a common issue. You might be able to adjust the preload on the driver side torsion bar. The adjustment should be somewhere under the car approximately where the driver seat is.
Is lean worse in Front or Rear? Use a measuring tape only all 4 corners, while on level pavement.
Rear LeafSprings on Explorer\MazdaB\Mountaineer\Ranger\SportTrac\...
are notoriously weak, tend to sag on Drivers side after a few years,
due to extra weight of Driver+FuelTank
