My Bronco 2
man my f150 did the same thing today! at about 5a, got it and it turned over so slow then i had to boost it with a booster pack and ever scince its been fine. but i cant understand why it started after work no probblem. and i cant leave my lights on if i do they turn themselves off after like 10 mins
no, mind needed jumped twice today. it cranked fine this morning going to the vet and going to my gf's house.. leaving my gf's was the problem.
I have an extra 1350M. :)
But it is junk and needs rebuilt. Bad bearings, seals and planetary
i have a 1350E laying around.. i have another 1354E laying around actually. and i think i have another d28 sitting down in Pontotoc. i have lots of parts i don't really need lol
Seeing the cable kit on the explorer forum, I think I will look into getting a 1354E and try my fab skill on making something similar... There are TONS of them around here.
yeah, i thought about trying to modify it.. if i can get the cable to move right, i can do it.
I was thinking a rod instead of cable. IDK
idk?? that's something to think about..
i figure out my battery problem!!!
my second battery (one i mentioned is like 2 years old) is bad, pulling my good battery down. my alt is charging tho. i isolated my batteries and checked them. the main battery tested good... so i'm putting a slow charge on it all night to build it back up. going tomorrow to look for a secondary battery. maybe a duralast gold? or another deep cycle marine starting battery like my main battery
i still have the new battery out of my other truck and would like to put it in to have dual setup. There is not enough room under the hood to do it though. Where do u have your second battery?
under the hood.
my main battery is the stock location (front passenger side) and my second battery is where the overflow tank was, i reloacted it to behind the cruise control box thingy and put the battery there (front driver side)
so they are exactly opposite of each other of the front
Pictures please, I will be doing this samething when I get a winch.
Shock towers
Battery pics soon
You forgot the battery set up pics :D
read what i wrote under the dang shock tower pics! be patient bro! lol
here ya go, i'm ashamed at how messy it is. i moved a lot of stuff around when i was tearing into my wiring trying to find my issue that turned out to the the ECM
but here ya go.
that's the driver side, how i moved my overflow tank, bent my cruise thing.. and i made a plate that the battery sites on, the plate has a bolt on it that holds the vacuum canister that was in the way. understand? lol
Event Coverage
TRS Merch
